Deutsche Bahn
The deutsche_bahn sensor will give you the departure time of the next train for the given connection. In case of a delay, the delay is also shown. Additional details are used to inform about, e.g., the type of the train, price, and if it is on time.
To enable this sensor, add the following lines to your configuration.yaml file:
  - platform: deutsche_bahn
    to: NAME_OF_FINAL_STATION
from string Required
The name of the start station.
to string Required
The name of the end/destination station.
offset time (Optional, default: 0.0)
Do not display departures leaving sooner than this number of seconds. Useful if you are a couple of minutes away from the stop. The formats “HH:MM” and “HH:MM:SS” are also supported.
only_direct boolean (Optional, default: false)
Only show direct connections.
This sensor stores a lot of attributes which can be accessed by other sensors, e.g., a template sensor.
template:
  - sensor:
    - name : "Next departure"
      state: "{{ state_attr('sensor.munich_to_ulm', 'next') }}"
The data is coming from the bahn.de website.
