Brel Home
Support for devices by Brel Home in Home Assistant is provided by the Motionblinds integration.
Brel Home devices are either rebranded devices or devices that share a common communication protocol, making it possible to use them with the Motionblinds integration.
To add the Brel Home integration to your Home Assistant instance, use this My button:
Brel Home can be auto-discovered by Home Assistant. If an instance was found, it will be shown as Discovered. You can then set it up right away.
  • From the list, select Brel Home.
Usage information
For more documentation on how to use Brel Home in Home Assistant, please refer to the Motionblinds integration documentation page.
