Blue Current
Blue Current
The Blue Current integration allows you to connect to your blue current account to Home Assistant and monitor your charge point(s).
- Log in to my.bluecurrent.nl
. - Click on your username and go to settings.
- Enable advanced options.
- Click on your username again and go to advanced.
- Generate an API token.
To add the Blue Current hub to your Home Assistant instance, use this My button:
From the list, select Blue Current.
Sensor
The Blue Current integration provides the following sensors:
Charge point sensors
- Activity
- Average current
- Average voltage
- Energy usage in kWh
- Max usage in Amps
- The max amps the charge point can use.
- Offline since
- Started on
- Stopped on
- Total cost in EUR
- Total power (estimate)
- Vehicle status
The following sensors are created as well, but disabled by default:
- Current phase 1-3
- offline max usage
- remaining current
- smart charging max usage
- Voltage phase 1-3
Grid sensors
- Grid average current
- Grid max current
- Grid current phase 1-3
Button
The Blue Current integration provides the following buttons:
Charge point buttons
- Reset
- Reboot
- Stop charge session
Actions
The following actions are provided by the Blue Current integration:
Action: Start charge session
The blue_current.start_charge_session action allows you to start a new charge session. When no charging card ID is provided, no charging card will be used.
| Data attribute | Optional | Description |
device_id |
no | Charge point device ID |
charging_card_id |
yes | Charging card ID that will be used to start a charge session. |
Switch
The Blue Current integration provides the following switches:
- Toggle Plug & Charge
- Allows you to start a session without having to scan a card.
- Toggle linked charging cards only
- When enabled, visitors can’t make use of the charge point. Only linked charging cards are allowed.
- Toggle charge point block
- Enables or disables a charge point.
