Bliss Automation
Support for devices by Bliss Automation in Home Assistant is provided by the Motionblinds integration.
Bliss Automation devices are either rebranded devices or devices that share a common communication protocol, making it possible to use them with the Motionblinds integration.
To add the Bliss Automation integration to your Home Assistant instance, use this My button:
Bliss Automation can be auto-discovered by Home Assistant. If an instance was found, it will be shown as Discovered. You can then set it up right away.
  • From the list, select Bliss Automation.
Usage information
For more documentation on how to use Bliss Automation in Home Assistant, please refer to the Motionblinds integration documentation page.
