Xiaomi Binary Sensor
The xiaomi aqara binary sensor platform allows you to get data from your Xiaomi binary sensors.
The requirement is that you have setup the xiaomi aqara integration.
Type of sensors supported
Name Zigbee entity Model no. States Event Event key Event values
Motion Sensor (1st gen) motion RTCGQ01LM on, off xiaomi_aqara.motion
Motion Sensor (2nd gen) sensor_motion.aq2 RTCGQ11LM on, off xiaomi_aqara.motion
Xiaomi Door and Window Sensor (1st gen) magnet MCCGQ01LM on, off
Aqara Door and Window Sensor (2nd gen) sensor_magnet.aq2 MCCGQ11LM on, off
Smoke Detector smoke JTYJ-GD-01LM/BW on, off
Gas Leak Detector natgas JTQJ-BF-01LM/BW on, off
Water Leak Sensor sensor_wleak.aq1 SJCGQ11LM on, off
Button (1st gen) switch WXKG01LM on (through long_click_press), off xiaomi_aqara.click click_type long_click_press, long_click_release, hold, single, double
Button (2nd gen) sensor_switch.aq2, remote.b1acn01 WXKG11LM off (always) xiaomi_aqara.click click_type single, double
Button (2nd gen, model b) sensor_switch.aq3 WXKG12LM off (always) xiaomi_aqara.click click_type single, double, long_click_press, shake
Aqara Wireless Switch (Single) 86sw1 WXKG03LM off (always) xiaomi_aqara.click click_type single
Aqara Wireless Switch (Double) 86sw2 WXKG02LM off (always) xiaomi_aqara.click click_type single, both
Aqara Wireless Switch (Single) (2nd gen) remote.b186acn01 WXKG03LM off (always) xiaomi_aqara.click click_type single, double, long
Aqara Wireless Switch (Double) (2nd gen) remote.b286acn01 WXKG02LM off (always) xiaomi_aqara.click click_type single, double, long, both, double_both, long_both
Cube cube MFKZQ01LM off (always) xiaomi_aqara.cube_action action_type, action_value (rotate) flip90, flip180, move, tap_twice, shake_air, swing, alert, free_fall, rotate (degrees at action_value)
Vibration Sensor vibration DJT11LM off (always) xiaomi_aqara.movement movement_type vibrate, tilt, free_fall
Automation examples
Motion
- alias: If there is motion and its dark turn on the gateway light
  trigger:
    platform: state
    entity_id: binary_sensor.motion_sensor_158d000xxxxxc2
    to: 'on'
  condition:
    condition: numeric_state
    entity_id: sensor.illumination_34ce00xxxx11
    below: 300
  action:
    - service: light.turn_on
      entity_id: light.gateway_light_34ce00xxxx11
        brightness: 5
    - service: automation.turn_on
        entity_id: automation.MOTION_OFF
- alias: If there no motion for 5 minutes turn off the gateway light
  trigger:
    platform: state
    to: 'off'
    for:
      minutes: 5
  action:
    - service: light.turn_off
    - service: automation.turn_off
        entity_id: automation.Motion_off
Door and/or Window
- alias: If the window is open turn off the radiator
  trigger:
    platform: state
    entity_id: binary_sensor.door_window_sensor_158d000xxxxxc2
    to: 'on'
  action:
    service: climate.set_operation_mode
    entity_id: climate.livingroom
      operation_mode: 'Off'
- alias: If the window is closed for 5 minutes turn on the radiator again
  trigger:
    platform: state
    to: 'off'
    for:
      minutes: 5
  action:
      operation_mode: 'Smart schedule'
- alias: Notify if door is opened when away
  trigger:
    platform: state
    entity_id: binary_sensor.door_window_sensor_15xxxxxxc9xx6b
    to: 'on'
  condition:
    - condition: state
      entity_id: group.family
      state: 'not_home'
  action:
    - service: notify.notify_person
        message: 'The door has been opened'
Smoke
- alias: Send notification on fire alarm
  trigger:
    platform: state
    entity_id: binary_sensor.smoke_sensor_158d0001574899
    to: 'on'
  action:
    - service: notify.html5
        title: Fire alarm!
        message: Fire/Smoke detected!
    - service: xiaomi_aqara.play_ringtone
        gw_mac: xxxxxxxxxxxx
        ringtone_id: 2
        ringtone_vol: 100
Gas
- alias: Send notification on gas alarm
  trigger:
    platform: state
    entity_id: binary_sensor.natgas_sensor_158dxxxxxxxxxx
    to: 'on'
  action:
      data_template:
        title: Gas alarm!
        message: 'Gas with a density of {{ state_attr('binary_sensor.natgas_sensor_158dxxxxxxxxxx', 'density') }} detected.'
Xiaomi Wireless Button
As indicated in the table on top of this page there are 3 versions of the button. For the round shaped button the available events are single, double, hold, long_click_press and long_click_release. Aqara branded buttons are square shaped. Model WXKG11LM only supports single and double events. WXKG12LM supports single, double, long_click_press and shake events. For the Aqara versions the delay between two clicks to generate a double click must be larger than with the round button. Clicking too quickly generates a single click event.
- alias: Toggle dining light on single press
  trigger:
    platform: event
    event_type: xiaomi_aqara.click
    event_data:
      entity_id: binary_sensor.switch_158d000xxxxxc2
      click_type: single
  action:
    service: switch.toggle
    entity_id: switch.wall_switch_left_158d000xxxxx01
- alias: Toggle couch light on double click
  trigger:
    platform: event
    event_data:
      click_type: double
  action:
    entity_id: switch.wall_switch_right_158d000xxxxx01
- alias: Let a dog bark on long press
  trigger:
    platform: event
    event_data:
      click_type: long_click_press
  action:
      ringtone_id: 8
      ringtone_vol: 8
Xiaomi Cube
Available events are flip90, flip180, move, tap_twice, shake_air, swing, alert, free_fall and rotate. The integration stores the last action as the attribute last_action.
- alias: Cube event flip90
  trigger:
    platform: event
    event_type: xiaomi_aqara.cube_action
    event_data:
      entity_id: binary_sensor.cube_15xxxxxxxxxxxx
      action_type: flip90
  action:
      entity_id: light.gateway_light_28xxxxxxxxxx
        color_name: "springgreen"
- alias: Cube event flip180
  trigger:
    platform: event
    event_data:
      action_type: flip180
  action:
        color_name: "darkviolet"
- alias: Cube event move
  trigger:
    platform: event
    event_data:
      action_type: move
  action:
        color_name: "gold"
- alias: Cube event tap_twice
  trigger:
    platform: event
    event_data:
      action_type: tap_twice
  action:
        color_name: "deepskyblue"
- alias: Cube event shake_air
  trigger:
    platform: event
    event_data:
      action_type: shake_air
  action:
        color_name: "blue"
The Aqara Wireless Switch is available as single-key and double-key version. Each key behaves like the Wireless Button limited to the click event single. The double key version adds a third device called binary_sensor.wall_switch_both_158xxxxxxxxx12 which reports a click event called both if both keys are pressed.
- alias: Decrease brightness of the gateway light
  trigger:
    platform: event
    event_data:
      entity_id: binary_sensor.wall_switch_left_158xxxxxxxxx12
      click_type: single
  action:
    entity_id: light.gateway_light_34xxxxxxxx13
    data_template:
      brightness: >-
        {% if state_attr('light.gateway_light_34xxxxxxxx13', 'brightness') %}
          {% if state_attr('light.gateway_light_34xxxxxxxx13', 'brightness') - 60 >= 10 %}
            {{state_attr('light.gateway_light_34xxxxxxxx13', 'brightness') - 60}}
          {% else %}
            {{state_attr('light.gateway_light_34xxxxxxxx13', 'brightness')}}
          {% endif %}
        {% else %}
          10
        {% endif %}
- alias: Increase brightness of the gateway light
  trigger:
    platform: event
    event_data:
      entity_id: binary_sensor.wall_switch_right_158xxxxxxxxx12
      click_type: single
  action:
    data_template:
      brightness: >-
          {% if state_attr('light.gateway_light_34xxxxxxxx13', 'brightness') + 60 <= 255 %}
            {{state_attr('light.gateway_light_34xxxxxxxx13', 'brightness') + 60}}
          {% else %}
          {% endif %}
        {% else %}
          10
        {% endif %}
- alias: Turn off the gateway light
  trigger:
    platform: event
    event_data:
      entity_id: binary_sensor.wall_switch_both_158xxxxxxxxx12
      click_type: both
  action:
Vibration Sensor
This automation toggles the living room lamp on vibration/tilt.
- alias: Turn on Living Room Lamp on vibration
  trigger:
    platform: event
    event_type: xiaomi_aqara.movement
    event_data:
      entity_id: binary_sensor.vibration_xxxx000000
      movement_type: vibrate
  action:
    service: light.toggle
      entity_id: light.living_room_lamp
- alias: Turn on Living Room Lamp on tilt
  trigger:
    platform: event
    event_data:
      movement_type: tilt
  action:
