KNX Binary Sensor
The knx integration must be configured correctly to use this integration, see KNX Integration.
The knx sensor platform allows you to monitor KNX binary sensors.
Binary sensors are read-only. To write to the knx-bus configure an exposure KNX Integration - Expose.
The knx integration must be configured correctly, see KNX Integration.
binary_sensor:
  - platform: knx
    state_address: '6/0/2'
state_addressstringRequired
KNX group address of the binary sensor.
namestring(Optional)
A name for this device used within Home Assistant.
sync_stateboolean(Optional, default: true)
Actively read the value from the bus. If False no GroupValueRead telegrams will be sent to the bus.
device_classstring(Optional)
significant_bitinteger(Optional, default: 1)
Specify which significant bit of the KNX value should be used.
reset_afterinteger(Optional)
Reset back to OFF state after specified milliseconds.
Automation actions
You can also attach actions to binary sensors (e.g., to switch on a light when a switch was pressed). In this example, one light is switched on when the button was pressed once and two others when the button was pressed a second time.
binary_sensor:
  - platform: knx
    state_address: '5/0/26'
    automation:
      - counter: 1
        hook: 'on'
        action:
          - entity_id: light.hue_color_lamp_1
            service: homeassistant.turn_on
      - counter: 2
        hook: 'on'
        action:
          - entity_id: light.hue_bloom_1
          - entity_id: light.hue_bloom_2
counterinteger(Optional, default: 1)
Set to 2 if your only want the action to be executed if the button was pressed twice. To 3 for three times button pressed.
hookstring(Optional, default: on)
Indicates if the automation should be executed on what state of the binary sensor. Values are “on” or “off”.
actionlist(Optional)
Specify a list of actions analog to the automation rules.
