BeagleBone Black GPIO
The bbb_gpio integration is the base for all BeagleBone Black related GPIO platforms in Home Assistant. There is no setup needed for the integration itself.
Binary Sensor
The bbb_gpio binary sensor platform allows you to read sensor values of the GPIOs of your BeagleBone Black.
To use your BeagleBone Black’s GPIO in your installation, add the following to your configuration.yaml file:
binary_sensor:
  - platform: bbb_gpio
    pins:
      P8_12:
      GPIO0_26:
pinsmapRequired
List of used pins.
pin_namemapRequired
Port numbers and corresponding names.
namestringRequired
Friendly name to use for the frontend.
bouncetimeinteger(Optional, default: 50)
Debounce time for reading input pin defined in milliseconds [ms].
invert_logicboolean(Optional, default: false)
If true, inverts the input logic to ACTIVE LOW
pull_modestring(Optional, default: UP)
Type of internal pull resistor connected to input. Options are UP - pull-up resistor and DOWN - pull-down resistor.
For more details about the GPIO layout, visit the article about the BeagleBone Black.
Switch
The bbb_gpio switch platform allows you to control the GPIOs of your BeagleBone Black.
switch:
    pins:
      GPIO0_7:
      P9_12:
pinsmapRequired
List of used pins.
pin_namemapRequired
namestring(Optional)
initialboolean(Optional, default: false)
Initial state of the pin.
