Apple TV
The Apple TV integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] allows you to control an Apple TV (any generation).
There is currently support for the following entities within the Apple TV device:
- Media Player
- Remote
Keyboard
binary_sensorand text input actions
To add the Apple TV device to your Home Assistant instance, use this My button:
Apple TV can be auto-discovered by Home Assistant. If an instance was found, it will be shown as Discovered. You can then set it up right away.
From the list, select Apple TV.
Media player
The Apple TV media player platform will create a Media Player entity for each Apple TV discovered on your network. This entity will display the active app and playback controls.
Launching apps
You can launch apps using the media_player.select_source action, or using the
“Apps” folder in the media browser.
Using the media_player.play_media action, you can also use Deep Links to
launch specific content in applications.
Examples of some Deep Links for popular applications:
| App | URL |
| YouTube | youtube://watch/dQw4w9WgXcQ |
| Netflix | https://www.netflix.com/title/80234304 |
| Disney+ | https://www.disneyplus.com/series/the-beatles-get-back/7DcWEeWVqrkE |
| Apple TV+ | https://tv.apple.com/show/severance/umc.cmc.1srk2goyh2q2zdxcx605w8vtx |
The simplest way to find useful Deep Links is to use the “Share” feature in iOS
or macOS versions of the App. Share sheets will often have a “Copy” or
“Copy link” feature. For apps that have a web-accessible version, links copied
from the browser usually work too. Such links may not work if a developer
maintains separate iOS and tvOS apps. More methods of discovering links
supported by apps can be found in the
pyatv documentation.
Examples:
# Open the Netflix app at a specific title
media_content_type: url
media_content_id: https://www.netflix.com/title/80234304
entity_id: media_player.living_room_apple_tv
# Open a specific YouTube video:
media_content_id: youtube://watch/dQw4w9WgXcQ
Remote
The Apple TV remote platform will automatically create a Remote entity for each Apple TV configured on your Home Assistant instance. These entities allow you to turn the device on/off and to send control commands.
The following commands are currently available:
wakeupsuspendhometop_menumenuselectplaypauseupdownleftrightvolume_upvolume_downpreviousnextskip_backwardskip_forward
NOTE: Not all commands are supported by all Apple TV versions.
Action send_command
| Service data attribute |
Optional | Description |
entity_id |
no |
entity_id of the Apple TV |
command |
no | Command, or list of commands to be sent |
num_repeats |
yes | Number of times to repeat the commands |
delay_secs |
yes | Interval in seconds between one send and another This is a float value e.g. 1, 1.2 etc. |
hold_secs |
yes | Number of seconds to hold the button. This is a float value but please use 0 for not hold and 1 for holding the button |
Examples
Create a script to invoke the Netflix application based on the application icon being in a fixed place on the home screen:
lounge_appletv_netflix:
alias: "Select Netflix"
sequence:
- action: remote.send_command
entity_id: remote.lounge_appletv
delay_secs: 1.5
command:
- top_menu
- home
- right
- select
Script using the quick action menu to send your Apple TV to sleep and turn off the Media Player:
apple_tv_sleep:
alias: "Make the Apple TV sleep"
sequence:
command:
- suspend
- action: media_player.turn_off
entity_id: media_player.lounge_appletv
Send 3 left commands with delay between each:
entity_id: remote.apple_tv
num_repeats: 3
delay_secs: 2.5
command:
- left
Keyboard
The Apple TV remote platform will automatically create a Binary sensor entity for each Apple TV configured on your Home Assistant instance to determine if the on-screen keyboard is active.
Example
Create an automation that clears the search text whenever the on-screen keyboard is activated:
description: "Always start with clear Apple TV search text"
mode: single
triggers:
- trigger: state
entity_id:
- binary_sensor.my_apple_tv_keyboard_focused
to: "on"
actions:
- action: apple_tv.clear_keyboard_text
config_entry_id: YOUR_CONFIG_ENTRY_ID
Three actions are available for sending text to the focused input field: Set keyboard text, Append keyboard text, and Clear keyboard text. They require that the keyboard is currently focused on the device.
The config_entry_id can be found under Settings > Devices & services > Apple TV > your device. It is the last part of the URL when viewing the device page.
Examples
Type a search query when the keyboard appears:
description: "Search for a show on Apple TV"
mode: single
triggers:
- trigger: state
entity_id:
to: "on"
actions:
- action: apple_tv.set_keyboard_text
text: "Severance"
List of actions
The Apple TV integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] provides the following actions. Each link below opens a dedicated page with examples, parameters, and a step-by-step UI walkthrough.
Append keyboard text (
apple_tv.append_keyboard_text) Appends text to the currently focused text input field on an Apple TV. -
Clear keyboard text (
apple_tv.clear_keyboard_text) Clears the text in the currently focused text input field on an Apple TV. -
Set keyboard text (
apple_tv.set_keyboard_text) Sets the text in the currently focused text input field on an Apple TV.
FAQ
My Apple TV does not turn on/off when I press on/off in the frontend
That is correct; it only toggles the power state in Home Assistant. See the example above to use the quick action menu. This can be used on Apple TVs running tvOS 14.0 or later.
Is it possible to see if a device is on without interacting with it
No
When adding a new device, a PIN code is requested, but none is shown on the screen
This can happen when pairing the AirPlay protocol if the access settings are too restrictive. On your Apple TV, go to Settings > AirPlay and HomeKit and make sure the access setting is set to Everyone on the Same Network, then try again.
If that does not resolve the issue, open the Home app on your iPhone or iPad, go to Home Settings > Speakers & TV, and set the access to Everyone. In some network configurations, the Everyone on the Same Network setting is not sufficient for the Apple TV to display the PIN prompt or for pairing to complete.
The buttons (play, pause, etc.) do not work
The tvOS apps themselves decide what commands they support and when they support them. Likely, the app you are using does not support the action you are trying to perform. Before writing an issue about this, verify if the same action is possible with the Remote app in iOS. If that is the case, please write a bug in pyatv and include logs (see Debugging below).
Setting volume doesn’t work on my Apple TV
Volume control functionality depends on how the Apple TV is set up. All volume controls should work if the Apple TV is connected to a HomePod or HomePod stereo pair. If the Apple TV is connected to TV speakers and with volume control over HDMI CEC (Settings -> Remotes and Devices -> Volume Control) only volume up/down controls will work. If volume control is over IR then volume cannot be controlled remotely through the Apple TV, but you can integrate your TV or soundbar directly.
I’m trying to play a stream via AirPlay, but it doesn’t work
The Apple TV is quite picky when it comes to which formats it plays. The best bet is MP4. If it doesn’t work, it’s likely because of the media format.
“No devices found on the network” error during setup even when connecting by IP
Ensure AirPlay is enabled and configured properly. See this FAQ entry.
Debugging
If you have any problems and intend to write an issue, make sure you have the relevant logs included. For this integration, you can enable them like this:
logger:
logs:
pyatv: debug
homeassistant.components.apple_tv: debug
By providing logs directly when creating the issue, you will likely get help much faster.
