Ambient Weather Station
The Ambient Weather Station
integration retrieves local weather information
via personal weather stations from Ambient Weather.
Setup
Using this integration requires both an Application Key and an API Key. To generate both, simply utilize the profile section of your Ambient Weather dashboard.
To add your Ambient Weather PWS to your Home Assistant installation, add the
following to your configuration.yaml
file:
ambient_station:
api_key: YOUR_API_KEY
app_key: YOUR_APPLICATION_KEY
Local API Option
This integration communicates with Ambient Weather PWS units via the Ambient Weather
Cloud. Users wishing to explore a local option are encouraged to explore the
Ecowitt GW1000, a small device that is
able to read RF signals directly from the PWS and transmit them to a variety of
other applications, including ecowitt2mqtt
(which supports MQTT Discovery).
