Alarm control panel
Home Assistant can give you an interface which is similar to a classic alarm system. Please see manual alarm or template alarm for alarm configuration.
Building block integration
The alarm control panel integration cannot be directly used. You cannot create your own alarm control panel entities using this integration. This integration is a building block for other integrations to use, enabling them to create alarm control panel entities for you.
Services
Depending on features supported by a specific integration alarm may expose the following services:
Service | Data | Description |
alarm_arm_home |
entity_id code (optional) |
Arm the alarm in the home mode. |
alarm_arm_away |
Arm the alarm in the away mode. |
alarm_arm_night |
Arm the alarm in the night mode. |
alarm_arm_vacation |
Arm the alarm in the vacation mode. |
alarm_disarm |
Disarm the alarm. |
alarm_trigger |
Trigger the alarm manually. |
alarm_arm_custom_bypass |
Send arm custom bypass command. |
