AirVisual Pro
The AirVisual Pro integration allows users to retrieve data from an AirVisual Node/Pro unit. Communication with the device occurs over the local network.
Determining the Password
You will need the device’s Samba password, which can be found on the unit.
Adding AirVisual Pro to your Home Assistant instance can be done via the user interface, by using this My button:
From the list, search and select “AirVisual Pro”.
Sensor Types
AirVisual Pro devices create a variety of sensors:
- Air Quality Index (AQI)
- Battery Level
- Carbon Dioxide (CO2)
- Humidity
- Particulate (<= 0.1 μm) (PM0.1)
- Particulate (<= 2.5 μm) (PM2.5)
- Particulate (<= 10 μm) (PM10)
- Temperature
- Volatile Organic Compounds (VOC)
