3 Day Blinds
Support for devices by 3 Day Blinds in Home Assistant is provided by the Motionblinds integration.
3 Day Blinds devices are either rebranded devices or devices that share a common communication protocol, making it possible to use them with the Motionblinds integration.
To add the 3 Day Blinds integration to your Home Assistant instance, use this My button:
3 Day Blinds can be auto-discovered by Home Assistant. If an instance was found, it will be shown as Discovered. You can then set it up right away.
  • From the list, select 3 Day Blinds.
Usage information
For more documentation on how to use 3 Day Blinds in Home Assistant, please refer to the Motionblinds integration documentation page.
