Ziggo Mediabox XL
The Ziggo Mediabox XL integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] allows you to control a Ziggo Mediabox XL from Home Assistant.
To add a Ziggo Mediabox XL to your installation, add the following to your configuration.yamlThe configuration.yaml file is the main configuration file for Home Assistant. It lists the integrations to be loaded and their specific configurations. In some cases, the configuration needs to be edited manually directly in the configuration.yaml file. Most integrations can be configured in the UI.[Learn more] file. After changing the configuration.yamlThe configuration.yaml file is the main configuration file for Home Assistant. It lists the integrations to be loaded and their specific configurations. In some cases, the configuration needs to be edited manually directly in the configuration.yaml file. Most integrations can be configured in the UI.[Learn more] file, restart Home Assistant to apply the changes. To view the changes, go to Settings > Devices & services > Entities.
media_player:
  - platform: ziggo_mediabox_xl
    host: 192.168.0.123
host string Required
The hostname or address of the device.
name string (Optional)
The name of the device used in the frontend.
The channel information (numbers and names) are downloaded from ziggo.nl on startup.
Preparation of the Mediabox
Makes sure to enable the Home Network (“mijn thuisnetwerk”) service in the settings menu of the media box. Once you have set up the Media Library (“mediabiblotheek”), we can determine whether the device is turned on or off. Without this, the integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] will fail to start.
