Xiaomi BLE
Integrates devices that implement the Xiaomi Mijia BLE MiBeacon protocol and other Xiaomi BLE devices that support passive collection. It listens to Bluetooth broadcasts that the device makes by itself, allowing us to track the latest sensor values without needing to wake it up from deep sleep to poll and conserving its battery power.
The integration will automatically discover devices once the Bluetooth integration is enabled and functional.
Adding Xiaomi BLE to your Home Assistant instance can be done via the user interface, by using this My button:
Supported device classes
It is possible that we detect your device because it uses the MiBeacon protocol but don’t yet support any or all of its sensors. We currently actively test devices with the following sensor classes.
  • Temperature
  • Humidity
  • Moisture
  • Illumination
  • Conductivity
  • Formaldehyde
  • Consumable
  • Voltage
  • Battery
It also supports the following classes of binary sensors:
  • Light
  • Smoke
  • Moisture
The entities for the sensor classes are added after the values are first received. This means entities for values that are broadcasted at a lower interval (e.g., battery) might show up later.
Encryption
Some devices use AES encryption to protect the sensor values they are broadcasting.
  • MiBeacon v2/v3 use unauthenticated AES with a 24 character hexadecimal (12 byte) key
  • MiBeacon v4/v5 use authenticated AES with a 32 character hexadecimal (16 byte) key
This key is called the bindkey or beaconkey.
There are a few ways to obtain a bindkey for your device:
  • Set your own. The Telink Flasher allows you to generate new bindkeys for devices it supports. The new bind key will work with Home Assistant, but the Mi Home app will not recognize the sensor anymore once the device has been activated by the TeLink flasher application. To use the sensor again with the Xiaomi Mi Home app, the device needs to be removed and then re-added inside the Mi Home app.
  • Extract the keys from Xiaomi Cloud using a token extractor tool.
Devices
Plant sensor: Flower Care / MiFlora (HHCCJCY01)
HHCCJCY01, also known as MiFlora or “Flower Care”, should be automatically discovered. However, if the firmware is too old, it won’t send the right BLE beacons and an update via the app is required. The lowest confirmed working firmware version is 3.2.1 (a lower 3.x version could also be alright).
Flower Care firmware update steps:
  • Install the official “Flower Care” app by HHCC:
  • Place the device with the app within 10cm of the plant sensor
  • Press the “+” button on the top right in the devices tab of the app
  • Add the plant sensor to the app and select an arbitrary plant
  • Wait for the synchronization of the sensor to finish, and a dialog asking for a firmware update should appear (this might take a few minutes)
  • The installed and latest firmware version can be verified by selecting the plant -> three-dot menu -> Hardware settings -> Hardware update
  • The Flower Care account and app are not required any further for this integration to work
