Tapo
Support for devices by Tapo in Home Assistant is provided by the TP-Link Smart Home integration.
Tapo devices are either rebranded devices or devices that share a common communication protocol, making it possible to use them with the TP-Link Smart Home integration.
To add the Tapo integration to your Home Assistant instance, use this My button:
Tapo can be auto-discovered by Home Assistant. If an instance was found, it will be shown as Discovered. You can then set it up right away.
From the list, select Tapo.
Usage information
For more documentation on how to use Tapo in Home Assistant, please refer to the TP-Link Smart Home integration documentation page.
