Somfy MyLink
The Somfy MyLink
integration is used as an interface to a compatible Somfy MyLink hub utilizing the Synergy
API. It allows the addition of covers from the Somfy MyLink platform to Home Assistant.
To use your compatible Somfy MyLink
devices in your installation, add the following to your configuration.yaml
file:
somfy_mylink:
host: IP_ADDRESS
system_id: SYSTEM_ID
The System ID
of the Somfy MyLink hub. This can be found in the Integration
menu in the mobile app.
Sets the default reversal status of the cover. Possible values are true
or false
. This value can be applied on a per-cover basis (see entity_config
below)
Configuration for specific cover entities. All subordinate keys are the corresponding entity ids to the domains, e.g., cover.bedroom_blinds
# Advanced configuration.yaml entry setting specific options on a per-cover basis
somfy_mylink:
host: IP_ADDRESS
default_reverse: true
entity_config:
cover.outdoor_awning:
reverse: false
