Ruuvi BLE
Integrates Ruuvi’s RuuviTag and Ruuvi Air BLE devices into Home Assistant.
To add the Ruuvi BLE integration to your Home Assistant instance, use this My button:
  • From the list, select Ruuvi BLE.
The Ruuvi BLE integration will automatically discover supported devices once the Bluetooth integration is enabled and functional.
If your Ruuvi devices are not discovered, please make sure to update them to the latest firmware.
Supported devices
  • RuuviTag - Environmental sensor tags
  • RuuviTag Pro - Heavy-duty environmental sensor tags
  • Ruuvi Air - Air quality monitors (since Home Assistant 2025.11)
