QNAP QSW
This integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] interacts with the local API of QNAP QSW managed switches
To add the QNAP QSW integration to your Home Assistant instance, use this My button:
QNAP QSW can be auto-discovered by Home Assistant. If an instance was found, it will be shown as Discovered. You can then set it up right away.
From the list, select QNAP QSW.
Binary sensors
The following binary sensors are created:
| Binary sensor | Description |
| anomaly | Device anomaly. |
The following binary sensors are created for each port (or LACP):
| link | Link status. |
Buttons
The following buttons are created:
| Button | Description |
| reboot | Reboot device. |
Sensors
The following sensors are created:
| Sensors | Description |
| fan_1_speed | Fan 1 Speed. |
| fan_2_speed | Fan 2 Speed. |
| ports | Number of used ports. |
| rx | Total RX bytes. |
| rx_errors | Total number of RX errors. |
| rx_speed | Total RX speed. |
| temperature | Switch temperature. |
| tx | Total TX bytes. |
| tx_speed | Total TX speed. |
| uptime | Uptime seconds. |
The following sensors are created for each port (or LACP):
| link_speed | Link speed. |
| rx | RX bytes. |
| rx_errors | Number of RX errors. |
| rx_speed | RX speed. |
| tx | TX bytes. |
| tx_speed | TX speed. |
Update
| Update | Description |
| firmware_update | Firmware update status. |
menu. Then, select Delete.
