Pure Energie
The Pure Energie integration integrates the Pure Energie Monitor device with Home Assistant.
The Pure Energie meter is a product that allows you to read the data from your smart meter via the serial port (P1), such as your energy consumption and power flow.
The product of Pure Energie is a white label product of Net2Grid, other white label products may be found by zeroconf and work with this integration.
To add the Pure Energie integration to your Home Assistant instance, use this My button:
Pure Energie can be auto-discovered by Home Assistant. If an instance was found, it will be shown as Discovered. You can then set it up right away.
SmartBridge
Read out what your meter readings are for energy consumption/production and see what your current power flow is.
  • Power Flow (W)
  • Energy Consumption (kWh)
  • Energy Production (kWh)
