Panasonic Viera
The Panasonic Viera integration allows you to control a Panasonic Viera TV.
- Media player
- Remote
To add the Panasonic Viera integration to your Home Assistant instance, use this My button:
From the list, select Panasonic Viera.
If your TV needs to be paired, you will be prompted to type the PIN code that will be displayed on it.
To allow your TV to be turned on or controlled while off, enable Powered On By Apps
in your settings (if available): Network > TV Remote App Settings
Manual configuration
If you prefer to use YAML to set up your Panasonic Viera TV, you can still do it. It also allows for some extra settings.
panasonic_viera:
host: YOUR_TV_IP
When you restart Home Assistant, make sure the TV is turned on and connected to your local network. If your TV needs to be paired, you’ll need to go to Settings > Devices & Services to type the PIN code that will be displayed on it and finish the setup.
Example turn_on_action
This example uses a turn_on_action
, to turn on the TV using a magic wake on
LAN packet. This example requires the Wake on LAN
integration to be set up.
# Example turn_on_action configuration.yaml entry with Wake-on-LAN
panasonic_viera:
host: YOUR_TV_IP
name: Living Room TV
turn_on_action:
- service: wake_on_lan.send_magic_packet
mac: "AA:BB:CC:DD:99:1A"
Example play_media script
The play_media
function can be used to open web pages and other media types (images, movies) via URLs in the TV web browser.
# Example play_media script
script:
front_door_camera:
alias: "Show who's at the door"
sequence:
- service: media_player.turn_on
entity_id: media_player.living_room_tv
- service: media_player.play_media
media_content_type: "url"
media_content_id: YOUR_URL
- delay:
seconds: 5
- service: media_player.media_stop
Remote
When the integration is configured, two entities will be created: a media_player
and a remote
. The remote allows you to send key commands to your TV with the remote.send_command
service.
Some of the known valid key values are:
up
down
left
right
enter
home
back
power
The list with all known valid keys can be found here. Additionally, you can also send custom commands, such as "NRC_HOME-ONOFF"
(which is the same as home
). Further undocumented commands are "NRC_HDMI1-ONOFF"
, "NRC_HDMI2-ONOFF"
, "NRC_HDMI3-ONOFF"
and "NRC_HDMI4-ONOFF"
for selecting HDMI inputs and "NRC_NETFLIX-ONOFF"
, "NRC_APPS-ONOFF"
, “NRC_MYAPP-ONOFF
” for apps.
Currently known supported models
- TC-P50ST50
- TC-P55ST50
- TC-P60S60
- TC-P60ST50 (can’t power on)
- TC-P65VT30
- TH-32ES500
- TH-P60ST50A (can’t power on)
- TX-32AS520E
- TX-32DSX609
- TX-40CXE720
- TX-40DX600
- TX-40DX700B
- TX-42AS650
- TX-49DX650B
- TX-50DX700B
- TX-55ASM655
- TX-55ASW654
- TX-55CS630E (can’t power on)
- TX-55CX680B
- TX-55CX700E
- TX-55EXW584
- TX-55EXW604S
- TX-55FX680W
- TX-55FZ802B
- TX-55JZ1000W
- TX-58AX802B
- TX-58DX700B
- TX-58DX800E
- TX-65CX800E
- TX-65EXW784
- TX-65FX720W
- TX-L42ET50
- TX-L47ET60E (can’t power on)
- TX LF37E30 (can’t power on)
- TX-P42STW50
- TX-P42VT30E
- TX-P50GT30Y
- TX-P50GT60E
- TX-65HZ1000W
If your model is not on the list, give it a test. If everything works correctly, then add it to the list on GitHub.
