Panasonic Blu-Ray Player
The panasonic_bluray
platform allows you to control a Panasonic Blu-Ray player. Note that the device must be on the same subnet as Home Assistant; connections from a different subnet will return an error.
Currently known supported models:
- DMP-BDT120
- DMP-BDT220
- DMP-BDT221
- DMP-BDT320
- DMP-BDT500
- DMP-BBT01
If your model is not on the list, then give it a try, if everything works correctly then add it to the list on GitHub.
Example configuration:
media_player:
- platform: panasonic_bluray
host: 192.168.0.10
Supported operations
- These devices support play, pause, stop and power on/off operations. They will also report the current status, title duration and current playing position.
