Open-Meteo
The Open-Meteo integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] integrates the free weather forecast from Open-Meteo with Home Assistant.
Open-Meteo offers free weather forecast APIs for open-source developers and non-commercial use. No account or API key is required to use this service.
Open-Meteo collaborates with National Weather Services providing Open Data with 1 to 11 km resolution. Their high-performance APIs select the best weather model for your location.
To add the Open-Meteo service to your Home Assistant instance, use this My button:
  • From the list, select Open-Meteo.
