Everything but the Kitchen Sink
The Kitchen Sink integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] contains demonstrations of various odds and ends.
This sets up a demo environment of features which are obscure or which represent incorrect behavior, and are thus not wanted in the demo integration.
To enable the kitchen_sink integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] in Home Assistant, add the following section to your configuration.yamlThe configuration.yaml file is the main configuration file for Home Assistant. It lists the integrations to be loaded and their specific configurations. In some cases, the configuration needs to be edited manually directly in the configuration.yaml file. Most integrations can be configured in the UI.[Learn more] file. After changing the configuration.yamlThe configuration.yaml file is the main configuration file for Home Assistant. It lists the integrations to be loaded and their specific configurations. In some cases, the configuration needs to be edited manually directly in the configuration.yaml file. Most integrations can be configured in the UI.[Learn more] file, restart Home Assistant to apply the changes.
kitchen_sink:
