JVC Projector
The JVC Projector integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] allows for the automation of JVC Projectors
Supported models
This integration is intended for the automation of any modern JVC Projector with a network port.
JVC is requiring newer 2024+ models to use a user-generated password to access the network port for security reasons.
To set up these models:
- Set a password on the projector’s network setup page.
- Use this password when adding the JVC Projector integration in Home Assistant.
To add the JVC Projector device to your Home Assistant instance, use this My button:
From the list, select JVC Projector.
Remote
The JVC Projector remote platform will create a Remote entity for the device. This entity allows you to send the following commands via the remote.send_command action.
menuupdownleftrightokbackinfoinputhidempccmdadvanced_menupicture_modecolor_profilelens_controlsetting_memorygamma_settingshdmi_1hdmi_2mode_1mode_2mode_3lens_apgammacolor_tempnaturalcinemaanamo3d_format
Binary sensor
The following sensor types are supported:
- Power on is True when projector is in status “on”, “warming”
Sensor
Introduces two sensors to detect Power Status and HDMI Input.
Detailed Power Status values:
standbyonwarmingcoolingerror
Please note that if the projector is off, it will not respond to remote polling and will show as unavailable.
Detailed HDMI Input values:
hdmi1hdmi2
Selects
The following Select entities are added. They allow changing the device state from a list of options.
input
