HERE Travel Time
The here_travel_time sensor provides travel time from the HERE Routing API.
Setup
You need to register for an API key (REST & XYZ HUB API/CLI) by following the instructions here.
HERE offers a Freemium Plan which includes 250,000 free Transactions per month. For the Routing API, one transaction equals one request with one starting point (no multi stop). If you are not updating sensors on demand you can track 28 routes without exceeding the limit. More information can be found here
By default HERE will deactivate your account if you exceed the free Transaction limit for the month. You can add payment details to re-enable your account as described here
Adding HERE Travel Time to your Home Assistant instance can be done via the user interface, by using this My button:
Notes:
  • Origin and Destination can be the address or the GPS coordinates of the location. For a dynamic configuration you can also enter an entity id which provides this information in its state, an entity id with latitude and longitude attributes, or zone friendly name (case sensitive).
Options
Options for HERE Travel Time can be set via the user interface, by taking the following steps:
  • If multiple instances of HERE Travel Time are configured, choose the instance you want to configure.
  • Select the cogwheel, then select Configure.
Dynamic Configuration
Tracking can be set up to track entities of type device_tracker, zone, sensor, input_select, input_text and person. If an entity is placed in the origin or destination then each time the platform updates, it will use the latest location of that entity. This means it will directly use its location if possible or try to resolve entity values until it finds a valid set of coordinates. You can put several destinations as options of an input_select and define that as the destination.
# Example entry for configuration.yaml
input_select:
  here_destination_preset:
    options:
      - zone.home
      - zone.office
      - zone.somewheredefault
  • device_tracker
    • If the state is a zone, then the zone location will be used
    • If the state is not a zone, it will look for the longitude and latitude attributes
  • person
  • zone
    • Uses the longitude and latitude attributes
  • sensor
    • If the state is a zone, then will use the zone location
    • If the state is a name of another entity it will recursively resolve entity states until if finds a valid set of coordinates
  • input_select
  • input_text
Updating sensors on-demand using Automation
You can also use the homeassistant.update_entity service to update the sensor on-demand. For example, if you want to update sensor.morning_commute every 2 minutes on weekday mornings, you can use the following automation:
automation:
- id: update_morning_commute_sensor
  alias: "Commute - Update morning commute sensor"
  initial_state: "on"
  trigger:
    - platform: time_pattern
      minutes: "/2"
  condition:
    - condition: time
      after: "08:00:00"
      before: "11:00:00"
    - condition: time
      weekday:
        - mon
        - tue
        - wed
        - thu
        - fri
  action:
    - service: homeassistant.update_entity
        entity_id: sensor.morning_commute
