Harman Kardon AVR
The Harman Kardon AVR integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] allows you to control Harman Kardon Network Receivers from Home Assistant.
Supported devices:
- Harman Kardon AVR-151S
- Other Harman Kardon AVR receivers (untested)
To add a Harman Kardon Network Receiver to your installation, add the following to your configuration.yamlThe configuration.yaml file is the main configuration file for Home Assistant. It lists the integrations to be loaded and their specific configurations. In some cases, the configuration needs to be edited manually directly in the configuration.yaml file. Most integrations can be configured in the UI. [Learn more] file.
After changing the configuration.yamlThe configuration.yaml file is the main configuration file for Home Assistant. It lists the integrations to be loaded and their specific configurations. In some cases, the configuration needs to be edited manually directly in the configuration.yaml file. Most integrations can be configured in the UI. [Learn more] file, restart Home Assistant to apply the changes. The integration is now shown on the integrations page under Settings > Devices & services. Its entities are listed on the integration card itself and on the Entities tab.
media_player:
- platform: harman_kardon_avr
host: IP_ADDRESS
A few notes:
- The newest firmware automatically shuts down the AVR after a certain amount of time. The AVR is then not available on the network anymore, so the โonโ command will not work.
- The AVR has no endpoints to determine the volume, muted, or playing, so if the remote control is used, HA will not know the new states of the device.
