Amazon Fire TV
Support for devices by Amazon Fire TV in Home Assistant is provided by the Android TV integration.
Amazon Fire TV devices are either rebranded devices or devices that share a common communication protocol, making it possible to use them with the Android TV integration.
Adding Amazon Fire TV to your Home Assistant instance can be done via the user interface, by using this My button:
From the list, search and select “Amazon Fire TV”.
Usage information
For more documentation on how to use Amazon Fire TV in Home Assistant, please refer to the Android TV integration documentation page.
