EufyLife
The EufyLife integration allows you to integrate Eufy smart scales with Home Assistant.
Supported devices
Note
This integration does not support the Wi-Fi capabilities of the P2 and P2 Pro. It can only connect to your smart scale via Bluetooth.
Features
All smart scale models provide a weight sensor entity and a real-time weight sensor entity. The real-time weight entity updates in real time while the scale is taking a weight measurement. The weight entity updates with the final weight value only when the scale is finished taking a weight measurement.
The Smart Scale P2 Pro additionally provides a heart rate sensor entity that will display the most recent heart rate measurement taken by the scale.
The EufyLife integration will automatically discover devices once the Bluetooth integration is enabled and functional. Alternatively, follow the steps below to add the integration manually.
To add the EufyLife device to your Home Assistant instance, use this My button:
