DLNA Digital Media Renderer
The dlna_dmr
platform allows you to control a DLNA Digital Media Renderer, such as DLNA enabled TVs or radios.
Please note that some devices, such as Samsung TVs, are rather picky about the source used to play from. The TTS service might not work in combination with these devices. If the play_media service does not work, please try playing from a DLNA/DMS (such as MiniDLNA).
Adding DLNA Digital Media Renderer to your Home Assistant instance can be done via the user interface, by using this My button:
DLNA Digital Media Renderer can be auto-discovered by Home Assistant. If an instance was found, it will be shown as Discovered. You can then set it up right away.
In the sidebar, select Settings.
From the configuration menu, select Devices & Services.
In the bottom right, select the Add Integration button.
From the list, search and select DLNA Digital Media Renderer.
Options
Options for DLNA DMR devices can be set going to Settings -> Devices & Services -> DLNA Digital Media Renderer -> Configuration.
Local port to listen on for events sent by the DLNA device. If this is not set, a random port will be allocated. Use this if you need a specific incoming port for firewall or NAT reasons.
Local URL destination for events sent by the DLNA device. It should be of the form http://{host}:{port}/notify
, where keywords {host}
and {port}
will be automatically filled-in but can be set explicitly here, e.g. http://192.88.99.1:5555/notify
. Use this if the local IP address or port seen by Home Assistant is not what the device should connect to, because of Network Address Translation (NAT).
Periodically try to connect to the DLNA device, even if it is unavailable. Enable this if SSDP advertisements sent by the device are not received by Home Assistant, e.g. when IP multicast is broken on your network.
Services
DLNA devices can support a range of features. Depending on the device itself, the following media_player services may be supported:
media_player.volume_up
,media_player.volume_down
, andmedia_player.volume_set
media_player.volume_mute
media_player.media_play
media_player.media_pause
andmedia_player.media_play_pause
media_player.media_stop
media_player.media_next_track
media_player.media_previous_track
media_player.play_media
media_player.shuffle_set
media_player.repeat_set
media_player.select_sound_mode
Playing media
Most DLNA DMR devices can play media from local HTTP servers. For best results, use HTTP instead of HTTPS, and refer to the server using an IP address instead of a hostname, e.g. http://192.168.1.1:8080/song.mp3
Media sources
The DLNA Digital Media Renderer integration can browse any configured Media Source. Displayed media will be filtered based on the capabilities of the DLNA DMR device.
