Azure DevOps
The Azure DevOps integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] allows you to control and monitor your Azure DevOps instance in Home Assistant.
To add the Azure DevOps service to your Home Assistant instance, use this My button:
  • From the list, select Azure DevOps.
Sensors
This integration provides a sensor for Azure DevOps:
  • Latest build - The build number of the latest build.
  • Latest build id - The ID of the latest build.
  • Latest build reason - The reason the build was triggered.
  • Latest build result - The build result.
  • Latest build source branch - The source git branch.
  • Latest build source version - This is the version, that is, the tag if set, or the commit.
  • Latest build status - The build status.
  • Latest build queue time - How long the latest build was queued.
  • Latest build start time - The time when the latest build actually started.
  • Latest build finish time - The time when the latest build finished.
  • Latest build URL - The URL to the latest build.
  • Work item count - The number of work items for each work item type and state in the project.
