Aurora ABB PowerOne Solar PV
This integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] implements a direct RS485 connection to a solar inverter in the PVI-3.0/3.6/4.2-TL-OUTD ABB series, and may work on others. The inverter was formerly made by PowerOne who got taken over by ABB.
The TCP/IP method of communicating with inverters is supported by the Python library, but not by this implementation in this integration.
This integration creates the inverter as a device with three sensors, reporting live power output in Watts, energy generated in kWh and device temperature.
Note the PV inverter will be unresponsive to communications when in darkness, so the sensors will report ‘Unavailable’ during the night.
The RS485 connection can be made using a low-cost USB-RS485 converter. It works using a 2-wire interface but an interface with a separate ground reference may be more reliable.
To add the Aurora ABB PowerOne Solar PV device to your Home Assistant instance, use this My button:
  • From the list, select Aurora ABB PowerOne Solar PV.
The inverter will need to be on (that is, in daylight) and connected correctly to do the first-time setup. Normally it is sufficient to select the correct serial port and leave the default address 2.
