Arcam FMJ Receivers
The arcam_fmj
integration allows you to control Arcam FMJ Receivers from Home Assistant.
Supported devices:
- SR 250
- AVR 380
- AVR 390
- AVR 450
- AVR 550
- AVR 750
- AVR 850
- AVR 860
- AV 860
- SA 10
- SA 20
- SA 30
Adding Arcam FMJ Receivers to your Home Assistant instance can be done via the user interface, by using this My button:
Arcam FMJ Receivers can be auto-discovered by Home Assistant. If an instance was found, it will be shown as “Discovered”, which you can select to set it up right away.
If there wasn’t any discovered automatically, don’t worry! You can set up a manual integration entry:
From the list, search and select “Arcam FMJ Receivers”.
Power state
Arcam FMJ receivers turn off their network port when in standby, the component will try to reconnect to the receiver every 5 seconds. This means powering on the first zone is not possible over the built-in network connection. Two options for complete power control exists: IR or Serial gateway.
IR command
Use an IR blaster to send a command to turn the device on using these discrete codes:
- Zone 1: Protocol: RC5 Device: 16 Function: 123
- Zone 2: Protocol: RC5 Device: 23 Function: 123
Turn on sometime requires two IR codes to be sent. You can generate the raw, broadlink or other IR format string using irgen tool like:
irgen -i rc5 -d 16 0 123 -o broadlink_base64 -r 2
To trigger this IR command add an automation on the event arcam.turn_on
filtering on
the entity_id
of the media_player
zone entity. This can be added using device automations
or manually using normal automations.
Serial Port to network gateway
Use a network to a serial port gateway to connect to the serial port of the receiver. The serial port is always available and can power on the device. This is the most reliable communication method as well.
