ANWB Energie
Support for devices by ANWB Energie in Home Assistant is provided by the EnergyZero integration.
ANWB Energie devices are either rebranded devices or devices that share a common communication protocol, making it possible to use them with the EnergyZero integration.
To add the ANWB Energie integration to your Home Assistant instance, use this My button:
From the list, select ANWB Energie.
Usage information
For more documentation on how to use ANWB Energie in Home Assistant, please refer to the EnergyZero integration documentation page.
