Trafikverket Camera
Retrieve camera feed from Trafikverket.
The name of the location needs to be precisely as Trafikverket has them. See examples and look for your camera here
Please click here and register to obtain the API key.
To add the Trafikverket Camera integration to your Home Assistant instance, use this My button:
From the list, select Trafikverket Camera.
Additional attributes
- Location (placement of camera)
- Description (free text description)
- Type (Type of camera)
