Raspberry Pi GPIO
The rpi_gpio
integration is the base for all related GPIO platforms in Home Assistant. There is no setup needed for the integration itself, for the platforms please check their corresponding pages.
Binary Sensor
The rpi_gpio
binary sensor platform allows you to read sensor values of the GPIOs of your Raspberry Pi.
To use your Raspberry Pi’s GPIO in your installation, add the following to your configuration.yaml
file:
binary_sensor:
- platform: rpi_gpio
ports:
11: PIR Office
12: PIR Bedroom
List of used ports.
The port numbers (BCM mode pin numbers) and corresponding names.
If true
, inverts the output logic to ACTIVE LOW.
false
(ACTIVE HIGH)
For more details about the GPIO layout, visit the Wikipedia article about the Raspberry Pi.
Cover
The rpi_gpio
cover platform allows you to use a Raspberry Pi to control your cover such as Garage doors.
It uses two pins on the Raspberry Pi.
- The
state_pin
will detect if the cover is closed, and - the
relay_pin
will trigger the cover to open or close.
Although you do not need Andrews Hilliday’s software controller when you run Home Assistant, he has written clear instructions on how to hook your garage door and sensors up to your Raspberry Pi, which can be found here.
To enable Raspberry Pi Covers in your installation, add the following to your configuration.yaml
file:
cover:
covers:
- relay_pin: 10
state_pin: 11
Invert the relay pin output so that it is active-high (True).
The direction the State pin is pulling. It can be UP or DOWN.
Invert the value of the State pin so that 0 means closed.
Full example
cover:
relay_time: 0.2
invert_relay: false
state_pull_mode: "UP"
invert_state: true
covers:
- relay_pin: 10
state_pin: 11
- relay_pin: 12
state_pin: 13
Remote Raspberry Pi Cover
If you don’t have Home Assistant running on your Raspberry Pi and you want to use it as a remote cover instead, there is a project called GarageQTPi that will work remotely with the MQTT Cover Component. Follow the GitHub instructions to install and configure GarageQTPi and once configured follow the Home Assistant instructions to configure the MQTT Cover.
Switch
The rpi_gpio
switch platform allows you to control the GPIOs of your Raspberry Pi.
file:
switch:
ports:
11: Fan Office
12: Light Desk
A common question is what does Port refer to, this number is the actual GPIO #, not the pin #. For example, if you have a relay connected to pin 11 its GPIO # is 17.
switch:
ports:
17: Speaker Relay
