Media source
The Media source integration platform allows integrations to expose media for use inside Home Assistant through the Media Browser panel or through supported media players like Google Cast.
This integration is configured automatically
through default_config or if another integration implements a media source.
If your configuration does not contain any of the above, you can add the below to your configuration file:
media_source:
Local media
By default, the integration looks for media in a specified folder.
If other media_dirs are not declared you need to use /media/local path for
example in companion app notification.
For Home Assistant OS, Supervised and Container users, this folder is by default
configured in the path /media.
Home Assistant OS and Supervised users can access this folder by using,
for example, the Samba add-on. Users of Home Assistant Container can
mount a volume of their choice to /media.
Files served from media are protected by Home Assistant authentication
unlike those served from www.
Using custom or additional media folders
It is also possible to set up custom and additional media directories. To do so, you’ll need to adjust the core configuration.
This example makes two different folders available to the integration:
homeassistant:
media_dirs:
local: /media
recording: /mnt/recordings
If you want to use media from a network storage, the network storage must be connected first. Refer to these instructions on how to connect network storage. The media from the network storage is then automatically added to the local media browser.
Playing media from a media source
To play media from a media source via an action, use the uri
scheme media-source://media_source/<media_dir>/<path>.
Default media_dir is local.
Web browsers and Google Cast media players have very limited video container and codec support. The media source integration does not do any transcoding of media, meaning media files must be natively supported by your media player or web browser (for playing in the frontend).
If a video file is not supported by your media player or web browser it will fail to play. Please check the documentation of your media player or web browser for lists of supported video formats.
Example:
entity_id: media_player.living_room_tv
media_content_type: "video/mp4"
media_content_id: "media-source://media_source/local/videos/favourites/Epic Sax Guy 10 Hours.mp4"
Identifying a media source from the media browser
If you wish to make use of the media-source:// URI for an action, and the media is already available in the media browser (either as locally stored on the Home Assistant machine, or mapped using network storage) the following steps can help to determine the media-source uri.
- Select Media in the sidebar.
- Navigate to the folder containing the media you wish to play.
In this example, we will go My media > NAS_Media. This folder is a network share containing a collection of .mp3 files. One of which is namedmy-music.mp3. - Copy the current URL from the URL bar.
for example:https://home-assistant.local/media-browser/browser/app%2Cmedia-source%3A%2F%2Fmedia_source/%2Cmedia-source%3A%2F%2Fmedia_source%2Flocal%2FNAS_Media - Search for an online URL Decoder, paste in the copied text and decode.
https://home-assistant.local/media-browser/browser/app,media-source://media_source/,media-source://media_source/local/NAS_Media
The last media source, in this case media-source://media_source/local/NAS_Media makes up the first part of the path, with the complete path being:
media-source://media_source/local/NAS_Media/my-music.mp3
