MQTT Device trigger
The mqtt
device trigger platform uses an MQTT message payload to generate device trigger events.
An MQTT device trigger is a better option than a binary sensor for buttons, remote controls etc.
MQTT device triggers are only supported through MQTT discovery, manual setup through configuration.yaml
The configuration.yaml file is the main configuration file for Home Assistant. It lists the integrations to be loaded and their specific configurations. In some cases, the configuration needs to be edited manually directly in the configuration.yaml file. Most integrations can be configured in the UI.[Learn more] is not supported.
The discovery topic needs to be: <discovery_prefix>/device_automation/[<node_id>/]<object_id>/config
. Note that only one trigger may be defined per unique discovery topic. Also note that the combination of type
and subtype
should be unique for a device.
The type of the trigger, e.g. button_short_press
. Entries supported by the frontend: button_short_press
, button_short_release
, button_long_press
, button_long_release
, button_double_press
, button_triple_press
, button_quadruple_press
, button_quintuple_press
. If set to an unsupported value, will render as subtype type
, e.g. button_1 spammed
with type
set to spammed
and subtype
set to button_1
The subtype of the trigger, e.g. button_1
. Entries supported by the frontend: turn_on
, turn_off
, button_1
, button_2
, button_3
, button_4
, button_5
, button_6
, e.g. left_button pressed
with type
set to button_short_press
and subtype
set to left_button
Information about the device this device trigger is a part of to tie it into the device registry. At least one of identifiers or connections must be present to identify the device.
A link to the webpage that can manage the configuration of this device. Can be either an http://
, https://
or an internal homeassistant://
URL.
A list of connections of the device to the outside world as a list of tuples [connection_type, connection_identifier]
. For example the MAC address of a network interface: "connections": [["mac", "02:5b:26:a8:dc:12"]]
A list of IDs that uniquely identify the device. For example a serial number.
Example
This shows a complete example of defining a remote control type device with two triggers: “left arrow click” and “right arrow click”.
Note that it is not necessary to provide the full device information in each message, but the identifying information, identifier
in the example, must be the same.
Left arrow click configuration
Discovery topic:
homeassistant/device_automation/0x90fd9ffffedf1266/action_arrow_left_click/config
Discovery payload:
{ "automation_type": "trigger", "type": "action", "subtype": "arrow_left_click", "payload": "arrow_left_click", "topic": "zigbee2mqtt/0x90fd9ffffedf1266/action", "device": { "identifiers": [ "zigbee2mqtt_0x90fd9ffffedf1266" ], "name": "0x90fd9ffffedf1266", "sw_version": "Zigbee2MQTT 1.14.0", "model": "TRADFRI remote control (E1524/E1810)", "manufacturer": "IKEA" } }
Trigger topic:
Trigger payload:
arrow_left_click
Right arrow click configuration
Discovery topic:
homeassistant/device_automation/0x90fd9ffffedf1266/action_arrow_right_click/config
Discovery payload:
{ "automation_type": "trigger", "type": "action", "subtype": "arrow_right_click", "payload": "arrow_right_click", "topic": "zigbee2mqtt/0x90fd9ffffedf1266/action", "device": { "identifiers": [ "zigbee2mqtt_0x90fd9ffffedf1266" ] } }
Trigger topic:
Trigger payload:
arrow_right_click
