Yandex Transport
The yandex_tranport
sensor platform uses Yandex Maps it will give you the time until the next departure time from a bus/tramway/etc stop.
The Yandex Maps website can help to determine the id of your bus stop. You can select a bus stop by clicking on the map, and look to the URL:
https://yandex.ru/maps/213/moscow/?ll=37.722565%2C55.806662&masstransit%5BstopId%5D=stop__9642962&mode=masstransit&z=16.52
Where stop id is: stop__9642962
If you want to track only specific routes, you can add them in the routes section.
To activate Yandex Transport, add the following lines to your configuration.yaml
- platform: yandex_transport
stop_id: YOUR_STOP_ID
A list of a specific bus, tramway, etc routes at the stop. This is the same as the bus number, e.g., 83
. If the routes with letters contain Cyrillic symbols, so write them to configuration.yaml
in Cyrillic.
Full configuration example
The configuration sample below shows how an entry can look like:
stop_id: stop__9639579
routes:
- 63
- 179
- 179к
- 154
- 591
- 677к
Options for entities
You can configure view information about the next bus using dashboard card.
To enable displaying the relative time in your default_view
add the following lines:
# Example default_view entry
title: Home Assistant
cards:
- entities:
- entity: sensor.yandex_transport
format: relative
type: entities
path: default_view
Data provided by https://maps.yandex.ru
