Wake on LAN
The Wake on LAN integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] enables the ability to send magic packets to Wake on LAN capable devices to turn them on.
To use this integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] in your installation, add the following to your configuration.yamlThe configuration.yaml file is the main configuration file for Home Assistant. It lists the integrations to be loaded and their specific configurations. In some cases, the configuration needs to be edited manually directly in the configuration.yaml file. Most integrations can be configured in the UI.[Learn more] file. After changing the configuration.yamlThe configuration.yaml file is the main configuration file for Home Assistant. It lists the integrations to be loaded and their specific configurations. In some cases, the configuration needs to be edited manually directly in the configuration.yaml file. Most integrations can be configured in the UI.[Learn more] file, restart Home Assistant to apply the changes. To view the changes, go to Settings > Devices & services > Entities.
wake_on_lan:
Integration services
Available services: send_magic_packet.
Service wake_on_lan.send_magic_packet
Send a magic packet to wake up a device with ‘Wake on LAN’ capabilities.
Service data attribute Optional Description
mac no MAC address of the device to wake up.
broadcast_address yes Optional broadcast IP where to send the magic packet.
broadcast_port yes Optional port where to send the magic packet.
Sample service data:
   "mac":"00:40:13:ed:f1:32"
This usually only works if the target device is connected to the same network. Routing the magic packet to a different subnet requires a special configuration on your router or may not be possible. The service to route the packet is most likely named "IP Helper". It may support Wake on LAN, but not all routers support this.
Switch
The wake_on_lan (WOL) switch integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] allows you to turn on a WOL enabled computer.
Switch configuration
The WOL switch can only turn on your computer and monitor the state. There is no universal way to turn off a computer remotely. The turn_off variable is there to help you call a script when you have figured out how to remotely turn off your computer. See below for suggestions on how to do this.
It’s required that the binary ping is in your $PATH.
To enable this switch in your installation, add the following to your configuration.yamlThe configuration.yaml file is the main configuration file for Home Assistant. It lists the integrations to be loaded and their specific configurations. In some cases, the configuration needs to be edited manually directly in the configuration.yaml file. Most integrations can be configured in the UI.[Learn more] file:
switch:
  - platform: wake_on_lan
    mac: MAC_ADDRESS
mac string Required
The MAC address to send the wake up command to, e.g, 00:01:02:03:04:05.
name string (Optional, default: Wake on LAN)
The name of the switch.
host string (Optional)
The IP address or hostname to check the state of the device (on/off). If this is not provided, the state of the switch will be assumed based on the last action that was taken.
turn_off string (Optional)
Defines an action to run when the switch is turned off.
broadcast_address string (Optional, default: 255.255.255.255)
The IP address of the host to send the magic packet to.
broadcast_port integer (Optional)
The port to send the magic packet to.
Examples
Here are some real-life examples of how to use the turn_off variable.
Suspending Linux
Suggested recipe for letting the turn_off script suspend a Linux computer (the target) from Home Assistant running on another Linux computer (the server).
  1. On the server, log in as the user account Home Assistant is running under. In this example it’s hass.
  2. On the server, create SSH keys by running ssh-keygen. Just press enter on all questions.
  3. On the target, create a new account that Home Assistant can ssh into: sudo adduser hass. Just press enter on all questions except password. It’s recommended using the same user name as on the server. If you do, you can leave out hass@ in the SSH commands below.
  4. On the server, transfer your public SSH key by ssh-copy-id hass@TARGET where TARGET is your target machine’s name or IP address. Enter the password you created in step 3.
  5. On the server, verify that you can reach your target machine without password by ssh TARGET.
  6. On the target, we need to let the hass user execute the program needed to suspend/shut down the target computer. Here is it pm-suspend, use poweroff to turn off the computer. First, get the full path: which pm-suspend. On my system, this is /usr/sbin/pm-suspend.
  7. On the target, using an account with sudo access (typically your main account), sudo visudo. Add this line last in the file: hass ALL=NOPASSWD:/usr/sbin/pm-suspend, where you replace hass with the name of your user on the target, if different, and /usr/sbin/pm-suspend with the command of your choice, if different.
  8. On the server, add the following to your configuration, replacing TARGET with the target’s name:
switch:
    turn_off:
      service: shell_command.turn_off_TARGET
shell_command:
  turn_off_TARGET: "ssh hass@TARGET sudo pm-suspend"
Helper button with automation
A switch defined with the wake_on_lan platform will render in the UI with both ‘on’ and ‘off’ clickable actions. If you don’t intend to use the turn_off functionality, then using a virtual button & automation will look cleaner and less confusing. It will only have one action.
  1. First, define a new helper button.
  2. Then, create a new automation. Go to Settings > Automations & scenes and select + Create Automation.
    • The trigger will be on State and the entity will be the button you created.
    • Continuing your example, the trigger YAML will look like this:
      platform: state
      entity_id:
        - input_button.wake_pc
  3. For the action, select Call service and choose Wake on LAN: Send magic packet.
  4. Type in the target MAC address.
    • Do not change the broadcast port unless you’ve configured your device to listen to a different port.
    • Continuing our example, the action YAML looks like this:
      service: wake_on_lan.send_magic_packet
        broadcast_port: 9
        mac: 00:11:22:33:44:55
  5. Save the automation. Now, when you activate PRESS on the helper button in the UI, Home Assistant will send a wake packet to the configured MAC.
