Queensland Bushfire Alert
The qld_bushfire
platform lets you integrate a
GeoRSS feed containing bushfire alerts for Queensland. It retrieves alerts from a feed
and shows information of those alerts filtered by distance to Home Assistant’s
location.
Entities are generated, updated and removed automatically with each update
from the feed. Each entity defines latitude and longitude and will be shown
on the default map automatically, or on a map card by defining the source
qld_bushfire
. The distance in kilometers is available as the state
of each entity.
The data is updated every 5 minutes.
The material used by this integration is provided under the Creative Commons Attribution 4.0 license. It has only been modified for the purpose of presenting the material in Home Assistant. Please refer to the creator’s copyright notice for more information.
To integrate the Queensland Bushfire Alert feed, add the following lines to
your configuration.yaml
geo_location:
- platform: qld_bushfire
List of category names found in the feed. Only alerts from the feed that match any of these categories are included. Valid categories are ‘Emergency Warning’, ‘Watch and Act’, ‘Advice’, ‘Notification’ and ‘Information’.
The distance in kilometers around Home Assistant’s coordinates in which bushfire alerts are included.
Latitude of the coordinates around which events are considered.
Latitude defined in your configuration
State attributes
The following state attributes are available for each entity in addition to the standard ones:
Attribute | Description |
latitude | Latitude of the bushfire alert. |
longitude | Longitude of the bushfire alert. |
source |
qld_bushfire to be used in conjunction with geo_location automation trigger. |
external_id | The external ID used in the feed to identify the bushfire alert in the feed. |
title | Original title from the feed. |
publication_date | Date and time when this alert was first published. |
updated_date | Date and time when this alert was last updated. |
status | Status of the alert, for example, “Patrolled”, “Going”, “Contained” |
Full configuration
geo_location:
radius: 30
categories:
- 'Emergency Warning'
- 'Watch and Act'
latitude: -24.85
longitude: 152.35
