RFLink binary sensor
The rflink
integration supports devices that use RFLink gateway firmware, for example the Nodo RFLink Gateway. RFLink gateway is an Arduino firmware that allows two-way communication with a multitude of RF wireless devices using cheap hardware (Arduino + transceiver).
First, you have to set up your RFLink hub.
The RFLink integration does not know the difference between a binary_sensor
, a switch
and a light
. Therefore all switchable devices are automatically added as light
by default.
RFLink binary_sensor/switch/light ID’s are composed of: protocol, id, switch/channel. For example: newkaku_0000c6c2_1
Once the ID of a binary sensor is known, it can be used to configure it as a binary sensor type in Home Assistant, for example, to hide it or configure a nice name.
Configuring a device as a binary sensor:
binary_sensor:
- platform: rflink
devices:
pt2262_00174754_0: {}
A list of binary sensors.
RFLink ID of the device
For sensors that only sends ‘On’ state updates, this variable sets a delay after which the sensor state will be updated back to ‘Off’.
Sensor state
Initially, the state of a binary sensor is unknown. When a sensor update is received, the state is known and will be shown in the frontend.
Device support
See device support
Additional configuration examples
Multiple sensors with custom name and device class and set off_delay
binary_sensor:
- platform: rflink
devices:
pt2262_00174754_0:
device_class: motion
off_delay: 5
pt2262_00174758_0:
name: PIR Living Room
off_delay: 5
