Ukraine Alarm
The Ukraine Alarm integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] uses the siren.pp.ua API - public wrapper for Ukraine Alarm web service to offer air-raid siren notifications. The integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] will create 6 binary sensors for your selected region in Ukraine:
- Air
- Artillery
- Chemical
- Nuclear
- Urban Fights
- Unknown
Siren check interval is set to 10 seconds to avoid overloading the API and still be able to react fast enough.
To add the Ukraine Alarm integration to your Home Assistant instance, use this My button:
From the list, select Ukraine Alarm.
Limitations
You can monitor up to 5 regions to not hit the API rate limit.
