TP-Link LTE
The TP-Link LTE integration for Home Assistant makes it possible to send SMS’s from the TP-Link LTE router. Phone numbers have to be pre-defined as part of the YAML configuration, and each phone number will turn up as additional notify service in Home Assistant. The integration adds a new notify service for each adds a notification service to Home Assistant that can be used to send SMSs provides a notification service that will send an SMS. Tested only with TL-MR6400 v4.
The integration provides a notification service that will send an SMS.
To enable the integration, add the following lines to your configuration.yaml
The configuration.yaml file is the main configuration file for Home Assistant. It lists the integrations to be loaded and their specific configurations. In some cases, the configuration needs to be edited manually directly in the configuration.yaml file. Most integrations can be configured in the UI.[Learn more] file:
tplink_lte:
- host: IP_ADDRESS
password: SECRET
notify:
- name: sms1
recipient: "+15105550123"
- name: sms2
recipient: "+55520525252"
