NOAA Tides
The noaa_tides
sensor integrationIntegrations connect and integrate Home Assistant with your devices, services, and more.
[Learn more] uses details from NOAA Tides and Currents to provide information about the prediction for the tides for any location in the United States.
Setup
This integrationIntegrations connect and integrate Home Assistant with your devices, services, and more.
[Learn more] requires the use of a NOAA station ID. Search NOAA Tide Predictions to find a location. Use the ID from the search results in your configuration. Alternatively, you can determine a station ID from a URL. For example, 8721164
in the following URL: https://tidesandcurrents.noaa.gov/noaatidepredictions.html?id=8721164
To use this integrationIntegrations connect and integrate Home Assistant with your devices, services, and more.
[Learn more], add the following to your configuration.yaml
- platform: noaa_tides
station_id: 8721164
ID of the station you’d like to track from https://tidesandcurrents.noaa.gov/tide_predictions.html.
User-selected timezone.
Local Standard Time/Local Daylight Time.
