eSterownik eCoal.pl Boiler
The ecoal_boiler
[Learn more] is the base for pumps and sensors managed by esterownik.pl eCoal boiler controller.
To use your eCoal pumps or sensors in your installation, add the following to your configuration.yaml
ecoal_boiler:
host: YOUR_IP_ADDRESS
username: YOUR_USERNAME
password: YOUR_PASSWORD
switches:
monitored_conditions:
- central_heating_pump
- central_heating_pump2
sensors:
- outdoor_temp
- indoor_temp
