Dublin Bus
The dublin_bus_transport
[Learn more] will give you the time until the next two departures from a Dublin bus stop using the RTPI information.
The Dublin Bus website can help to determine the id of your bus stop. You can check if this is correct by going to
https://data.dublinked.ie/cgi-bin/rtpi/realtimebusinformation?stopid=[Stop ID]
Then add the data to your configuration.yaml
- platform: dublin_bus_transport
stopid: STOP_ID
The public RTPI information is coming from Dub Linked.
