ComEd Hourly Pricing
The ComEd Hourly Pricing program is an optional program available to ComEd electric subscribers which charges customers a variable rate for electricity supply based on current demand rather than a traditional fixed rate. Live prices are published here and also via an API which we can integrate as a sensor in Home Assistant.
There are two price feeds available: the 5-minute price and current hour average price.
To use this sensor in your installation, add the following to your configuration.yaml
- platform: comed_hourly_pricing
monitored_feeds:
- type: five_minute
- type: current_hour_average
