Amazon Alexa Flash Briefing
Flash Briefing Skills
As of version 0.31 Home Assistant supports the new Alexa Flash Briefing Skills API. A Flash Briefing Skill adds a new Flash Briefing source that is generated by Home Assistant.
Requirements
Amazon requires the endpoint of a skill to be hosted via SSL. Self-signed certificates are OK because our skills will only run in development mode. Read more on our blog about how to set up encryption for Home Assistant. Using the Let’s Encrypt and Duck DNS add-ons is the easiest method. If you are unable to get HTTPS up and running, consider using this AWS Lambda proxy for Alexa skills.
Additionally, note that at the time of this writing, your Alexa skill endpoint must accept requests over port 443 (Home Assistant default to 8123). There are two ways you can handle this:
- In your router, forward external 443 to your Home Assistant serving port (defaults to 8123) OR
- Change your Home Assistant serving port to 443 this is done in the
http
section with theserver_port
entry in yourconfiguration.yaml
The configuration.yaml file is the main configuration file for Home Assistant. It lists the integrations to be loaded and their specific configurations. In some cases, the configuration needs to be edited manually directly in the configuration.yaml file. Most integrations can be configured in the UI.[Learn more] file
Configuring a Flash Briefing skill in Home Assistant
You can use templates for the title
, audio
, text
and display_url
configuration parameters.
Here’s an example configuration of a Flash briefing skill that will tell you who is at home:
alexa:
flash_briefings:
password: YOUR_PASSWORD
whoishome:
- title: Who's at home?
text: >
{%- if is_state('device_tracker.paulus', 'home') and
is_state('device_tracker.anne_therese', 'home') -%}
You are both home, you silly
{%- else -%}
Anne Therese is at {{ states("device_tracker.anne_therese") }}
and Paulus is at {{ states("device_tracker.paulus") }}
{% endif %}
You can add multiple items for a feed if you want. The Amazon required UID and timestamp will be randomly generated at startup and change at every restart of Home Assistant.
Please refer to the Amazon documentation for more information about allowed configuration parameters and formats.
Configuring your Flash Briefing skill
- Log in to Amazon developer console
- Click on the “Create Alexa Skills” button
- Click the blue “Console” button in the top right
- Click the light blue “Create Skill” button in the top right
- Skill Information
- You can enter whatever name you want
- For “Choose a model” select “Flash Briefing”
- Hit “Create Skill” in the top right corner
- Flash Briefing
- Enter a custom error message, like “This skill is currently not available.”
- Add new feed
- For Preamble, enter “From Home Assistant” (or anything you like)
- For Name, enter “Home Assistant”
- Choose Content type “Text”
- Select a genre, e.g. “Other”
- For Feed, enter
https://YOUR_HOST/api/alexa/flash_briefings/BRIEFING_ID?password=YOUR_PASSWORD
whereBRIEFING_ID
is the key you entered in your configuration (such aswhoishome
in the above example). NOTE: Do not use a non-standard HTTP or HTTPS port, AWS will not connect to it. - You can use this specially sized Home Assistant logo as the Feed Icon
- Hit “Add”
- Hit “Save” in the top right corner
- Test
- Having passed all validations to reach this screen, you can now click on “< Back to All Skills” as your flash briefing is now available as in “Development” service.
- Skill Information
- To invoke your flash briefing, open the Alexa app on your phone or go to the Alexa Settings Site, open the “Skills” configuration section, select “Your Skills”, scroll to the bottom, tap on the Flash Briefing Skill you just created, enable it, then manage Flash Briefing and adjust ordering as necessary. Finally ask your Echo for your “news”,“flash briefing”, or “briefing”.
